READ, EDIT, WRITE
VCM Editor the most comprehensive vehicle control module programmer and parameter editor.
Connect > Read > Edit > Write > Drive.
Packaging VCM Editor together with MPVI2 allows you to read most vehicles control modules flash memory and save it in our proprietary .HPT file structure. VCM Editor enables you to adjust a multitude of complex parameters such as torque strategies, spark tables, fueling, RPM limits, fan activations, transmission shift points and pressures, exhaust valve control, speedometer settings and many more. Finally, you write these changes back to the various vehicle control modules via the MPVI2.
VCM Editor‘s flash utility allows not just calibration reflashing and automated recovery, but entire VCM/PCM image reflashing. This means that you are free to make any operating system or calibration level modifications and flash those to the VCM/PCM. This has many uses for the advanced enthusiast, serious tuner or engine swap workshop, allowing complete control over the VCM/PCM software environment.
The VCM Editor also allows for increased vehicle support for tuners, along with access to extra VCM/PCM operating system code modifications. VCM Editor also allows the option to modify VIN’s, a useful feature for mail order VCM/PCMs.
VCM EDITOR
TECHNICAL SPECIFICATIONS
- Faster read time of most VCM/PCMs.
- Faster write most VCM/PCMs in 30 seconds.
- Automated VCM/PCM recovery protection (not supported on all vehicles)
- Seamless recovery after complete power down and communications break(exception for rewrite entire)
- Obtain the VCM/PCMs calibration information and ID numbers
- Calibration reflash (not supported on all vehicles)
- Full reflash
- VIN block reflash / change (not supported on all vehicles)
- Explorer style navigation
- Tab style navigation (tree optional)
- Undockable explorer navigator window
- Customizable favorites list which allows you to jump to frequently changed parameters (Example)
- Countless editable parameters
- Open multiple tables at once
- Save/Print/Load individual Tables
- Individually save tables/maps to txt format
- Table smoothing
- Table vertical and horizontal specific smoothing
- Table interpolating
- 2D Graph click and drag editing
- 3D Graph click and drag editing
- Simple +/- key cell adjustments
- 1 click copy/paste of tables
- Right click copy/paste/undo
- Right click unit adjustments
- Compare files with different OS ID’s
- Tree style compare logs
- Easy to use color system when in compare mode
- Calibration Details section to list vehicle details
- Tree style Change log
- Tree style History log
- Change log and History log parameter hyperlinks
- PCM DTC List
- Custom operating systems (VCM Enhancements)
- 1 Bar Speed Density Enhanced (GM Gen3 V8 and GM 4.3 V6 only)
- 2 Bar Speed Density (GM Gen3 V8 and GM 4.3 V6 only)
- 5 Bar Speed Density (GM Gen4 V8 only)
- 3 Bar Speed Density (GM Gen3 V8 and GM 4.3 V6 only)
- Built in unit conversion
- Built in calculator
Package the MPVI2 together with VCM Editor and VCM Scanner, which make up the essentials of VCM Suite, and you have one of the most powerful, scanning, diagnostic, logging and calibration products on the market. Not to mention full support for our latest rendition of Track Addict, whether you regular the drag strip, circuit, autocross or off-road the MPVI2 has the fastest scanning, logging and data transmission rates to ensure you capture everything.
